Fuel Pressure For 350
Old Mar 21, 2002 | 08:37 PM
BONES LB9's Avatar
WHAT TYPE OF FUEL PRESSURE SHOULD I RUN FOR A 350 READ SIGNATURE FOR SPECS. TIMING IS ADVANCED TO 8degrees
Old Mar 21, 2002 | 09:34 PM
Bort62's Avatar
Why Don't you start adjusting your's and find out what works best ?
Old Mar 21, 2002 | 09:42 PM
BONES LB9's Avatar
i wanted an idea about where to start cuz i can't think of what my stock fuel pressure was on the 305. Anyone know what their fuel pressure is on 350 tpi?
Old Mar 21, 2002 | 10:05 PM
Bort62's Avatar
Try starting around 38#
Old Mar 21, 2002 | 10:14 PM
BONES LB9's Avatar
ok thanks i guess i'll have to go by SOP performance and the BLM and a/f ratio
Old Mar 22, 2002 | 06:20 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well you can do it like the old timers in my shop, and use your nose. Which may work well with Model-T's, but not so well in FI applications.
Or you can measure the voltage on the o2 sensor, or buy one of them gauges.
38lbs is a good starting point.
-- Joe
Old Mar 22, 2002 | 07:14 AM
Z28DJP1987's Avatar
If you are using the stock 305 chip your fuel pressure is about 47/48 psi. As a starting point 41/44 psi for the 350 even with
the 24# injectors. Your A/F ratio is probably too rich right now.
My opinion.
Old Mar 23, 2002 | 12:55 AM
BONES LB9's Avatar
yeah it is running rich at the moment . I was expecting the motor to run poor or set crazy codes with the 305 ecm but it's not. I'm goin to switch in the 350 ecm saturday to see if it makes any difference. Runs strong i finally c the difference between the motors 305/350 it feels like a completely different car and i'm loving ever minute expect the fact that the heater core is leaking now i got to replace that.
has anyone every done one if so any suggestion?
and thanks for the info
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
