will not idle
Old Mar 22, 2002 | 10:27 AM
iroc_z16's Avatar
will not idle
Yesterday when i was in town my car died so is started it back and it would not idle for nothing. I had to put in neutral and keep it revved up then throw it in drive to go. I got home and messed with the throttle and now it idles fine. Anybody know what happened? Thanks.
Old Mar 22, 2002 | 10:29 AM
iroc_z16's Avatar
Oh i forgot i think it has a miss in it too
Old Mar 28, 2002 | 10:20 PM
spdde1's Avatar
try replacing the idle air control mine did the same thing went out then when i got it home it would idle then a few days later it got so were it would not idle at all it would rev up but not idle i replaced the thottle position sensor as a precaution
Old Mar 28, 2002 | 10:52 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Man, this is wierd! The '87 LB9 in my Monte SS is doing the same thing!
The car died on me a few weeks ago...turns out the ignition module in the distributor was fried, and toasted out the cap and rotor too. So we replaced everything, and I put in new plugs as well. Car ran GREAT for a few days, then I parked it cause I won't drive it to work.
Went out to start it about three days later, and she would not idle for ****. Same thing as your car, if I revved it up, it would smooth out, but otherwise, ran crappy. So, I left it alone. Last night, I went out for the hell of it, and started it. Ran perfect, so I took it out for a ride. Put about 40 miles on it, no trouble at all. Though, I did notice the idle was very high in Park last night after shutting down and restarting a while later.
Decided to take it to work today, and she wouldn't idle again this AM! WTF?? I'm thinking IAC as well, anyone else have this happen??
Old Mar 28, 2002 | 11:38 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
did check engine light ever come on?
Old Mar 29, 2002 | 03:42 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
When my car did something similar, it turned out that my computer was fried.
Old Mar 29, 2002 | 06:27 AM
Car: 1988 Monte SS
I'm not sure about IROC_Z16s car, but mine hasn't. I need to check it for stored codes though, maybe there's a clue there.
Old Mar 29, 2002 | 10:58 PM
Car: 1988 Monte SS
Update
I took my car out tonite again, and checked the ECM for stored codes. None at all. The car seemed to run fine, but there are some other oddities now I need to check out. Both fans are on all the time, and the torque converter locks when I lift off the throttle, and unlocks when I step on it. I think I have to reset the brake switch.
Old Mar 30, 2002 | 09:32 AM
spdde1's Avatar
my ck engine light never came on when my air idle controller went out but it did when my egr went bad
Old Apr 1, 2002 | 05:55 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My 92 did that and all i did was unplug the hose that went into that "charcoal canister" and she would idle fine. the idle rpm did jump up to almost a grand, from 750. I have not had the problem come up again since i did that well over a year ago.
Old Apr 2, 2002 | 07:03 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Let this thread know what you guys came up with to solve the problem 'cause something similar happened to me yesterday.
Old May 4, 2003 | 08:01 PM
sanchez's Avatar
Car: 1990 Iroc-z G92
Transmission: 5 Speed
would unplugging the charcoal canister mess anything up?
MY car has had the same problem on and for over a year so after replacing all of the vacuum hoses and replacing many sensors i decided to unplug the canister and now it has no funky idle Could it have just been an old charcoal canister that need to be replaced
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
