would this be a good about to port? (several pics)
Old Mar 23, 2002 | 12:53 AM
87transam5.7tpi's Avatar
got a couple of pictures here Please let me know what you think about each one of these ideas I also am siamesing the intake about four inches in Thanks for the time!
the caption says "should I cut out the walls or just smooth em up?"
Attached Thumbnails would this be a good about to port? (several pics)-pelnumgood3-copy.jpg
Old Mar 23, 2002 | 12:56 AM
caption says," Is it ok if I also cut down the side and bottom walls?"
Attached Thumbnails would this be a good about to port? (several pics)-plenum-copy.jpg
Old Mar 23, 2002 | 12:57 AM
caption says "I'm going to match the top and bottom so they are both siamesed a tad"
also thanks again!
Attached Thumbnails would this be a good about to port? (several pics)-plenum2-copy.jpg
Old Mar 23, 2002 | 10:03 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
You might want to think twice about siamessing the bottom of the runners unless you plan on doing them all the way through. This could create some weird effects. Remember, siamesing your intake is in essence just shortening the length of your runners, which will shift your power band up. A search of this board will produce intake runner lengths of other intakes (super-ram, mini-ram, LT1, LS1, ect.) that you might like the power band of, giving you a reference of how long you want you're runners to be. Really, you don't want to do this unless your cam and heads are designed to take advantage of a higher operating range (ie. not stockers).
Just some food for thought.
Old Mar 25, 2002 | 09:56 AM
ttt
Old Mar 25, 2002 | 11:24 AM
tpi_roc's Avatar
Check out the tech article on porting/siamesing an tpi setup
it'll provide your answers with pictures.
Old Mar 25, 2002 | 12:03 PM
Archael's Avatar
what the hell is "ttt" i keep seeing it and figgering i should know but i don't
Old Mar 25, 2002 | 12:06 PM
tpi_roc's Avatar
ttt to the top
btt back to the top
or
(obvious)
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Linson
Aug 21, 2015 02:12 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
