Cooling fan switch& Temp gauge swtich
Old Mar 25, 2002 | 10:54 AM
Team FTS's Avatar
Is the sensor in the drivers side cylinder head the temparature switch? and would the one in the passenger side head be the coolant fan switch. If they are those switches are those there correct names?
Old Mar 25, 2002 | 11:49 AM
92CamaroZ's Avatar
i don't know about the sensor on the drivers side, but I just swapped out my coolant fan switch and it was on the passenger side. This was for a 92Z with the 5.0.
Old Mar 25, 2002 | 11:51 AM
Team FTS's Avatar
Thank, Mine is a 91 Trans-am with a 5.0
Old Mar 25, 2002 | 11:12 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Temperature sensor on drivers side head is for temp. display on dash panel.
Old Mar 25, 2002 | 11:27 PM
Team FTS's Avatar
Thanks, I already replaced both the sensors though.
Old Mar 26, 2002 | 05:21 AM
ImportsRsloths's Avatar
I just ordered the jet fan swithc from summit ($40) that turns the fan on at 190 i think instead of 220..... does it go in the pass. or drivers side??? thanks matt
Old Mar 26, 2002 | 09:57 AM
Team FTS's Avatar
Passenger side.
Old Mar 27, 2002 | 02:20 AM
Jza's Avatar
Jza
Just so you don't confuse anyone when you're talking about those:
"Sensors" are typically ECM related. "Senders" are typically gauge related. And "switches" are just that: on/off according to it's function.
86IROC112
Sep 11, 2015 04:04 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
