better cam?
Old Mar 25, 2002 | 08:45 PM
Camaro90RS43's Avatar
better cam?
So i'm told that the cam in the stock 87 z-28 camaro was a piece of sh**, what would be a good cam to put in when everything else is still stock? Thanks
Old Mar 25, 2002 | 09:08 PM
rhuarc30's Avatar
comp cams 262xe or 268xe
Old Mar 25, 2002 | 09:11 PM
what kind of horsepower gain should i expect? and what are the specs of the cam? thanks.
Old Mar 25, 2002 | 10:00 PM
89Raptor
Guest
Posts: n/a
It is best to call Comp Cams and get them to help you select the best camshaft for your car. I did and I was glad I did, I had already picked out the cams I thought would be best after looking at about 100 and testing them on desktop dyno. Then I called Crane and tried theirs, they recommended the one I had chosen from their line. Then I called Comp Cams, they recommended a totally different cam than the one I had chosen. It actually looked to be a milder cam than the one I had selected. But I got the numbers and plugged it into desktop dyno and guess what. It showed an increase of 45 HP and no loss in torque, I was impressed so much so I bought the cam. 1-800-999-0853 is the number for cam help.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
