running rich?
running rich?
What could be causing me to run so rich? I can see raw fuel comming out of the exhaust at idle and when i rev it up? My fuel psi is at 43 and i have my chip burnned so my BLM's are between 126-132 at part throttle which is almost perfect AF ratio. Timming is at 6deg advanced and vacume is a steady 16 at idle? No codes..an occasional egr code, but that is a very tempramental code from what I have read. I have a new engine with AFR heads, sllightly larger cam and it seems very sluggish. Plugwires and plugs are good. Plugs under inspection at teh track show a rich condition?
Can anyone help??
Can anyone help??
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have a similiar problem with my car. But now I have a rod knocking so the T/A is going to be grounded for a bit.
