Do I need to replace cold start injector too?
Old Mar 31, 2002 | 06:26 PM
brian89transam's Avatar
If I end up replacing my injectors with 24# ones, should I find a new stock 22lb one to replace the cold start injector?
Old Mar 31, 2002 | 06:38 PM
Desert86Roc's Avatar
Fuel injectors and Cold Start Injectors are not interchangeable.
Old Mar 31, 2002 | 10:21 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
What "Desert86Roc" said is correct. Also when you change your injectors you do no need to replace the Cold Start Injector, it is a waste of money.
Old Apr 1, 2002 | 09:09 PM
I've heard a lot about cold start injectors leaking and causing problems (could be my problem). If I'm going to the trouble of replacing all the other injectors I figure I'd rather be safe than sorry. Where can I find a replacement?
Old Apr 2, 2002 | 01:28 PM
Rich at CruzinPerformance may be able to help you out if you insist on changing the injector.
However, I recommend having a custom EPROM burned using 89 era code, and eliminate the whole dang thing. Best thing I ever did to my fuel system. Completely solved my cold/warm start problems. Later TPIs use a fuel enrichment program instead of the mechanical "switch" for the CSI. You can then remove the Cold Start switch (in front of the manifold), the cold start injector, the fuel line to the rear of the fuel rail, and plug then plug the holes. I plugged the hole in the runners with an aluminum "slug". I didnt want to waste the fuel rail fitting, so I had half of a 4AN fitting welded onto the back of the stock fuel rail fitting and use it for my fuel pressure gauge sending unit.
Benefits:
- 2 less things to go wrong with your fuel setup (leaks, breaks)
- Cleaner looking engine (less plumbing)
- later (better) EPROM coding
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
