Can I Remove Carcoal Canister?
Old Mar 31, 2002 | 08:18 PM
RED91Z's Avatar
ON my 91 Z28 TPI with out throwing codes?????
Old Mar 31, 2002 | 10:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
i removed my canister along with AIR pump and cats and did not get any codes. just put a rubber cap on the tb where the hose use to go to from the canister.
Old Apr 1, 2002 | 05:47 PM
u r sofa king we tah did's Avatar
putting a rubber cap on the hose isnt smart since thats the gas tanks vent line.
Old Apr 1, 2002 | 07:45 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Yeah I agree...No on the rubber cap...You basically have 2 choices...1 vent the tank through a vented gas cap or 2 Vent the tank..
I first tried the vented gas cap idea...Its a pita and did not work well...Its a pita because the only vented gas cap you can buy is one where you tighten it then turn 3/4 of a turn off to vent it....The idea is to keep the hiss controlled not to be a VENT.... Well the pita is remembering too turn it to vent everytime you get gas... PLUS I found that with a full tank it would spray fuel on the side of the car....
Here is what I did...works great...Remove the metal line.....At the gas tank there was a rubber hose that attaches to the metal line....Get an IMPORT fuel filter...Plug the fuel filter into the rubber line.....Then run a hose down pointing at the ground from that....This will vent it peerfectly YET the filter will kill off any gas smell from the line...
Another more ghetto way to do it is to Keep the metal line and just attach a fuel filter and a hose to the underside of the front bumper.....
Ive never had it LEAK fuel BUT Just make sure ypou dont route the line towards exhaust...Better safe than dead..
Old Apr 2, 2002 | 01:00 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
He said to cap the Throttle Body, not the vent line.
Old Apr 2, 2002 | 02:47 PM
BOTTLEDZ28's Avatar
Transmission: A4
thank you zepher, someone didnt read my post thoughly. i installed new lines inmy 91z28 project and never even out a vapor line in the car. i just put the feed and eturn line. the vent tube just runs down the tank and hangs in the bacj near the rearend.
Old Apr 2, 2002 | 05:51 PM
whoops. my mistake. well now he knows not to cap the vent line...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
