info on stealth ram
Old Apr 9, 2002 | 10:14 AM
cobrakiller1989's Avatar
info on stealth ram
i posted this on another stealth ram topic, but figured i would put it here so more people would get the opportunity to see it. this quote is from holley's tech dept.
"As of right now we have not test fit this on the camaro. Hood clearance
may be an issue. The unit is 10 inches tall which is about 1 1/2 inches
taller than the stock manifold. The stock electronics should work as long
as you do not have the cold start injector. The fuel rail kit does include
the regulator and it is adjustable. The rpm range is idle-6500. Thanks"
Old Apr 9, 2002 | 10:21 AM
Snowdog 91 Formula's Avatar
What it looks like
Found the thread where I was able to get the pictures from Holley. They have them on their site, but they won't open normally so I had to use PhotoShop to convert the pictures for all to see.
https://www.thirdgen.org/techbb2/sho...threadid=97403
Old Apr 9, 2002 | 10:42 AM
BitchinCamaro's Avatar
Wouldn't that just be our luck, aftermarket finally makes a cheap alternative to minirams/superrams and then it won't fit under the stock hood.
Old Apr 9, 2002 | 01:26 PM
BenDoe91z28's Avatar
if you look close, it looks as if you could shave a fraction of an inch off the top of the towers on the manifold base...
Old Apr 9, 2002 | 02:10 PM
camaro6spd's Avatar
ALL THE MORE REASON TO GET A COUL HOOD
Old Apr 9, 2002 | 03:23 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Or a cowl hood
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
mfp189
Sep 27, 2015 09:25 AM
