what spark plugs
Old Apr 9, 2002 | 08:59 PM
TransAm87's Avatar
what spark plugs
Its time now that i change my plugs on my 87 T/A ...305 TPI..what is everyone using as plugs..as thinking about wires, cap and rotor..please help..
thanks
AJ
Old Apr 9, 2002 | 09:34 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
AC Delco or Bosch Platinum. For the other stuff MSD is always good.
Old Apr 9, 2002 | 09:40 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If you have the larger HEI dist try a HyperTech coil/cap/rotor, MSD SuperConductor wires, A/C Delco plugs with cut back ground electrodes (method on my site).
Old Apr 10, 2002 | 09:50 AM
camaro6spd's Avatar
i use rapid fires and have Accel 8.8mm Spark Plug Wires and Delco cap and rotor. Short and sweet.
Old Apr 10, 2002 | 03:23 PM
johndo1707's Avatar
rapid fires work great on the Jimmy, lol i got AC's in mine and worked much better than the crap that was in the car when i bought it from some moron, lol. cya gotchie
Gotchi:lala: :lala: :lala: :lala: :lala: :lala: :lala:
Old Apr 10, 2002 | 03:45 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
just get regular AC plugs.... as far as everything else is concerned MSD is awesome. I personally would steer away from Accel.
Old Apr 10, 2002 | 05:23 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Bosch platinums, and the rest MSD
Old Apr 10, 2002 | 07:33 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I would use the R45TS with 305. they seemed to run good in mine when I had a 305.
Old Apr 10, 2002 | 08:06 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Rapidfire by far, is the best plug. NGK's fouled out far too quick. They aren't worth the price. MSD's stuff is all good. I've had Accel 8mm wires on my car for over two years now & they are holding up to the voltage of the MSD 6A very well.
Old Apr 10, 2002 | 08:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ac delco works the best for me I tried accel and a few others the delco plugs are great! seem to last the best even when she was running rich.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
