how am i supposed to make this work?
Old Apr 10, 2002 | 02:12 PM
maddmonkees90rs's Avatar
ok i know that this is probably the wrong place to put this post but i need help from anyone that can offer it. so im doing a tpi swap to my 90rs. harness is diff so i order one from summit. well now i need an ecm i didnt know that they were diff, well i knew but i didnt know they were that diff. so now i need an ecm and ive called all the salvage places near by and none have ecms. i called thirdgen rescouces and they dont have any ecms either. so right now im up a creek. ive been with out a car for threee weeks now. if anyone can help me locate an ecm i would be very grateful. by the way i have a harness and ecm out of a 87 tpi
and i have a harness and ecm out of a 90rs. i also called local part stores and they have the ecms with out proms and i know i need that. and if i purchase an ecm from them where can i get an inexpesive prom for a 90 tpi camaro. lol. well thanks to anyone that can help me.
Old Apr 10, 2002 | 02:19 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
you need an ecm and prom out of the same year as the tpi intake was. if you took the tpi off an 87 then you need an 87 ecm with an 87 prom. because of the differences in tpi. they switched to speed density instead of mass air in i believe 89 or 90 i can't ever remember. so a 90 prom wont work with an 87 ecm.
you can always get a new ecm and get an aftermarket prom also.
Andrew
*edit*
i think i misread your post but i'll leave this up until you say otherwise
Old Apr 11, 2002 | 12:08 AM
Swapmaster's Avatar
What is your location, I can tell you where to get one if I knew
where you were at. The prom is easy, just call a Chevy dealer,
they cost like 35 or 40 dollars or something like that.
Old Apr 11, 2002 | 03:31 PM
cfabe's Avatar
check ebay too, theres always tpi ecms up on there.
Old Apr 11, 2002 | 06:35 PM
yeah i called the local dealer....they want 800 for the prom. well im in south texas relaly really south texas, the rgv. south padre island is near by. well i think the jet preformance chip i found online for 150 is the way im goin for the prom. anyone have feed back on it? i would burn my own if i knew how or had the equipment ... but i dont have time for that anyways. if anyone can help me get a good prom for less money. i would be really grateful thanks oh and i got an ecm off of ebay. i over paid but that was my fault. lol so now i just need the prom please help
Old Apr 11, 2002 | 07:25 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I did the same swap in my 90rs. I bought a speed density ecm from street and performance for $125.
Old Apr 11, 2002 | 09:22 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Jet (and all the other "off-the-shelf") eproms are a complete waste of money. Better off with just the stock eprom, because that is what those Jet eproms really are (with a dash more spark and fuel...NOTHING that will give any additional performance).
A stock eprom/memcal will cost around $40-60 depending if it's MAF or SD. And you can get the SD ECM at a wrecking yard for under $50 .... just say it's for an early 90s 3.1 V6 Cavalier/Sunbird.
The dealership that quoted $800 "must have seen you coming".
But if you AREN'T going to learn how to burn eproms, then just stick with the stock Memcal and use "mechanical methods" to tune. Mechanical Methods are not the right way to tune an engine but they do a hell of a lot more than an "off-the-shelf" eprom. BTW, you'll probably spend as much on "mechanical methods" and still not get the performance or gas mileage that you'd get from tuning your own eprom.
The money you save in gas in just one year pays for all the equipment, and then you can save FOREVER. But it's your money, do as you wish.
Old Apr 11, 2002 | 11:29 PM
its not the preformace i want. i just want a chip that will get my car running. and i cant find eproms any where. and i tried for those ecms in the salvage yards already. they aint got any. some one wanna get me a prom from thier local dealer and mail it to me and ill pay you back. everyone keeps talkin trash about proms i really have no choice.... so u tell mewill my car turn on and will it run fine with no problems? cus if it will im willing to buy a prom from jet preformance or fast chips. either way i have no other choice. unless some one knows a site online where i can get the factory online. id like to konw.
Old Apr 11, 2002 | 11:39 PM
Gruvin84SS's Avatar
order a stock prom from www.gmpartsdirect.com with a part number, you can get it shipped to you for less than 50.00 and i am sure someone will have you the part number as mne is SD, my prom will not fit a MAF system so my part number will not work.
Also look in the tech section of this site, it tells what ECM service tag you need and can be found in many cars and only needs a prom change. Again my spare ECM will not fit your MAF system so i can't be of help there either.
Old Apr 12, 2002 | 12:03 AM
thanks gruvin and evryone else. especially u glen. thing is although its an 87 block and tpi setup, i want it setup to run like a 90 same 90 pulley setup and a map (sd) setup not maf. i was told all i have to do is block off the 9th injector. but if u guys think that cant be done then let me know. i got the wiring harness for the 90 setup(painless) gonna get the ecm. just need the prom. thats what im tryin to get. lemme try that site. but id like for any other input u guys can give. thanks again.
anyone with a 90 sd 305 tpi auto camaro would u mind lending me ur vin# its so i could order the prom. thanks for that too
Old Apr 12, 2002 | 04:48 AM
Gruvin84SS's Avatar
I am running parts from a 1985 TPI parts with a 90-92 wiring harness and ECM so it can be done. You can get a cold start injector plug for the manifold and the fuel rail so that you can delete these from your system.
Well, if you are wanting SD, then i have a spare ECM to fit. SD ECMs have three plugs on the wiring harness and the MAF ECMs only have two. If you are interested in the extra ECM that i have just let me know and we can work something out.
Since your car is a 90 RS, do you have VATS? you will need this to hook up to the ECM and wiring harness or you will have to get someone to reburn the factory prom with VATS deleted so that the prom will work.
Old Apr 12, 2002 | 07:48 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Problem solved
http://chevythunder.com/
Old Apr 12, 2002 | 08:04 AM
Car: Death Mobile
Engine: 666 c.i.
Gruvin is right. Just block of the Cold Start Injector, get the 1227730 SD ECM (they are a dime a dozen because they are the same ECM as early 90s 3.1 V6 Cavlier/Sunbirds - go to a "U Pick A Part" and find one, unless you live in some remote neck of the woods). And the Memcal you want is the AUJP1615, can be ordered in a couple days from almost ANY GM Dealership. I paid $65.00 when I bought my spare a year ago.
Go here http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/ to see how to do a MAF 165 Swap to a 7730 Swap. They even show how to convert the cable.
Old Apr 12, 2002 | 03:37 PM
ok i called a dealer that is a bout 60 miles away they were the only ones that new what an eprom or memcal was. but they want the vin#. so if anyone can help me at this point i would be really greatful. i need the vin for a 90 305 tpi auto tranny. or are we not allowed to ask for vin#s. well no junk yards here have any tpis so i cant go get one outta those. and my donor car was an 87 so that would defeat the pupose i need the vin# for that car. and i tried that number glenn but they said taht didnt find it. could it be another?
Old Apr 13, 2002 | 09:57 AM
BOTTLEDZ28's Avatar
Transmission: A4
madmonkey, where the heck do you live? $800 for a prom? holy crap. your local dealer must be selling new camaros for a million dollars. i bought a brand new ecm from auto zone for 80 bucks and a prom from fastchip for $185. ya i know some might say the ecm from autozone is junk but i needed one that day and they had one. it works so thats all that counts. i did buy about 3 diffrent chips from the dealer. what a nighmare. i literally have to look at their computer and show them what i want because they are so stupid. one guy tells me that there is no chip for a 91350 with tpi.
Old Apr 13, 2002 | 10:19 AM
Car: Death Mobile
Engine: 666 c.i.
GO FIND ANOTHER DEALER!!!!
The VIN# only contains the "engine type". It has no info on the "tranny" or "rear axle" within the code. While that is NOT a GM Part#, it IS the Broadcast Code which any GOOD dealership should cross link to your ECM.
Go to this link for a 305 Auto TPI bin AWFU5509 WITHOUT 16" Tires
http://holman.cs.uml.edu/~sdurphey/b...b.cgi?BCC=awfu
Or for a 305 Auto TPI with 16" tires AXXF3076
http://holman.cs.uml.edu/~sdurphey/b...b.cgi?BCC=axxf
I recommend the AXXF3076 because the 305 autos with 16" tires don't have a speed limiter!
Print this off, as it even has the proper GM part number. BUT GO TO ANOTHER DEALERSHIP!
Old Apr 13, 2002 | 12:11 PM
wooooooo hooooooooo now i just hope the ecm and eprom i get make the car work. well i just went and orderd the eprom for the 16inch wheels. yeah i got it at gmpartsdirect.com for 50 with shippping. not a bad deal cus the only dealer that wanted to get if for me wanted a vin# and wanted 80 plus shippnig. thanks glenn thats what i needed to look up the part. u can get rid of this post if u want. thanks again to everyon else for thier input.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
st.evel07
Aug 13, 2015 06:15 PM
novaderrik
Aug 10, 2015 12:44 PM
BrianI
Aug 9, 2015 11:52 AM
MENINBLK
Aug 5, 2015 11:58 PM
