ok ran my car on a lift still vibrates
Old Apr 15, 2002 | 02:21 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok i ran my car on the lift to 70mph where it vibrates badly, a guy was looking underneath and said the driveshaft was fine (2nd one in the car) i started getting this when i changed the flywheel/clutch/and rebuilt the transmission, ok so the vibration sounds like a vroom vrooom vrroom it will do it in 4th or 5th and is strongest at about 75-85 then diminishes slightly. what do you guys think it could be? when i press the clutch the wicked vibration goes away.
Old Apr 15, 2002 | 07:50 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sounds drive shaft related. Have your mechanic check drive line angles. The tail shaft of the trans should be up 1-2 degrees higher than the plane of the drive shaft & the rear pinion shold be 1-2 degrees down from the plane of the drive shaft. I just went through this problem myself after a rear & torque arm swap.
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
anesthes
Aug 8, 2015 09:37 PM
