What's everyone paying for gear installation?
Old Apr 16, 2002 | 12:19 PM
johndo1707's Avatar
i was wondering what you guys are paying to have your gears put in, i don't trust myself so...lol but i figure the gears are $180 for richmond 3.73's and the install kits go for around 100 and i just need to nkow how much shops usually charge to install them. thanks!:lala:
Old Apr 16, 2002 | 12:21 PM
fattie92's Avatar
i was told 150
Old Apr 16, 2002 | 02:01 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Find someone that knows what they're doing. I would stay away from anyone that would do it for $20 and a six pack, because if it is shimmed incorectly, you are gonna get premature wear, and a loud whine. It happened to a buddy of mine who has an lt1, and it really sucks.
Old Apr 16, 2002 | 02:16 PM
johndo1707's Avatar
yeah i figured that, i'm talking about at a garage or shop or something, anyone have this professionally done before?
Old Apr 16, 2002 | 02:33 PM
TBurke's Avatar
I had mine done for 135. I took the rear out of the car and took it over to the shop. I blew the gears apart so I couldn't have it done in the car.
Old Apr 16, 2002 | 03:28 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
call these guys, they can recommend a guy in your area , at least they did for me, i bought an auburn posi and 3.73 precision gears from em .........i think everything plus install cost me 1,000..........im sure you can get it done cheaper but i dont mind paying for no headaches............i beat the snot out of it and have no probs
http://www.reiderracing.com/
Old Apr 16, 2002 | 09:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
i had 3.73's installed in my 10 bolt and it cost me $400. i dropped the rearo ff also. i knmow it seems like a lot but i know the guy does good work and you get what you pay for. i had 4.10's put in my 97ws6 trans am and they lasted me 6 monthes and that cost me 200.
Old Apr 17, 2002 | 09:57 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Got mine done for $150 and turned out perfect. Wasn't by a shop though.
Old Jun 25, 2002 | 12:46 AM
hydra512's Avatar
i had richmond 3.73's and auburn posi put in. the total was 950. the guy charged me 200 for labor, good deal i think
Old Jun 25, 2002 | 02:53 PM
Joshua Leslie's Avatar
I was quoted 700 for new 3.42s, a posi unit, and the install, from a shop.
Old Jun 26, 2002 | 12:47 PM
hydra512's Avatar
what kinda posi and gears would they put in for you? parts alone for me were 700
Old Jun 27, 2002 | 05:44 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Richmond gears = $200
Installation kit = $100
Labor = $200
The only other cost is the posi (I got mine on sale for $300). So $700 is not a bad price depending on what parts you get.
Whatever you do, take it to a shop that is reputable and will stand behind their work. Get some opinions first. Good labor can cost good money. I've paid through the nose for some work from my mechanic but I have never had any problems after my car was fixed.
Old Jun 28, 2002 | 11:32 PM
NuclearPwrIroc's Avatar
About the six pack of beer and 20 buck install? whats wrong with that? i personally save the beer for afterwards, no drunk gear installation, esp when presses are involved. and the 20 bucks should cover things like gaskets and sealer, maybe diff fluid. Shops around here charge about 1k for a diff rebuild with gear install you can save about 600 in labor costs if you just do it yourself. not hard, also a note. gears are worn together from the factory,*** i forget the name of the machine that does it (patented machine/process), but yeah they are worn together so make sure you line them up the way they were intended, this doesnt apply to some gear ranges, just because some gear ranges are what is called non hunting, semi hunting care a little more hunting gear sets/ranges will create all kinds of noise, shimming, is damn easy the pinion tells youhow thick a shim it needs, i wont go into specifics about setting up side shims/bearing preload because different types of diffs use mostly the same procedure, but....not the same components neccessarily, what i might call a case might be a housing to you, or a carrier to me might be your case. but regardless that as well is REALLY easy....buy a pinion depth tool, about 100 bucks voila you can do gears....also by the way 4.10s are loud, they wear out fast and well did i mention they are loud?
hectre13
Dec 11, 2023 08:14 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
hectre13
Aug 26, 2015 08:17 AM
kyleb24
Aug 15, 2015 08:24 AM
dhonda200
Aug 11, 2015 11:50 PM
