Motor oil in NWC T5 ?
My friend just put a non world class T5 (84 model) in his Firebird and put 10W-40 motor oil in it. Is this better then gear lube ? The tranny has a pretty faint whine in almost all gears but 4 th. Is gear lube reccomended more ? If so... what weight should he use ? Thanx
Mine is a NWC and the B&W T5 service manual states...Due to the tight tolerances held in the T5, Dexron II ATF is the required fluid. Premature synchronizer and blocking ring wear will result if the improper fluid is used.
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
