just bought a t56, what clutch to get?????????
need a clutch for this, but not sure what to get, jegs has one and it's $540! Must be others out there...any help would be great
Car: 1989 IROC
I would not recommend centerforce for the T56. I have read many complaints about the centerforce in the T56s, they do noy have a good reputation. I had a STAR clutch, which I recommend and many also recommend Mcleod clutches.
Tim
Tim
After much research I went with a lt4 pressure plate and the mcleod disk. I havent driven it yet (thanks to spohn and holley, still waiting on parts) but If you ask me in 2 weeks I should be able to tell you how it is.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I've got the same setup as cfabe. I have, unfortunately, a slight problem with clutch chatter. But damn, the clutch GRABS!
thanks guys
thanks for your opionions, could you guys tell me where to get these clutchs for the cheapest, also, check out my new forum on my site, gonna put a spot on there for camaro's
http://www.soundsolutionsaudio.com
I got my LT4 pressure plate and LT1 flywheel from Dal (lockitup@bright.net), and I got my mcleod disc from Thunder Racing.
pressure plate
Am I gonna need a new pressure plate, I allready have a 5spd in my car, is there anything i'll need besides the cross memeber, I allready ordered that yesterday from spohn, how is he on shipping?
You sure are, the T56 utilizes a pull style clutch instead of a push style. You'll need a specific flywheel too--if you've got a one-piece RMS engine, the stock LT1 flywheel will work, otherwise you have to go aftermarket.
Need more details.
The stock 94-97 T56 utilizes a pull style clutch. Nothing will interchange from a T5.
I don't even know what kind of car or transmission you currently have.
I dont know if its just me, but it seems like people are getting lazy with the search button of late. All the t-56 swap info has been gone over already.
Real quick tho, if you're coming from a t-5 car to a t-56, you 'll need to get: tranny, bellhousing, clutchfork, hydraulics, crossmember, flywheel, pressure platew/ t.o. bearing, clutch disk, all the right bolts, some of which you can get a the hardware and some you can't, shifter, some electrical connectors if you want reverse lights and speedo, speedo recalibration box. I may have missed a few things.
Re: pressure plate
Originally posted by BigMInstalls
...the cross memeber, I allready ordered that yesterday from spohn, how is he on shipping?
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I have the LT4 Pressure plate with the Mcleod clutch. 99hawk is right, there is a little clutch chatter but you'll get use to it and get it smooth. Thats probably one of the cheapest and best option. You can also get a STAR clutch from thunder racing with I've heard, is very good. They have many stages to suit your needs. Good luck with T56.
99Hawk120: Car make model
sorry, didn't tell you guys the car I have...
91 Z28 5spd , C5 Chrome wheels, Leather, white face gauges, etc..soon to have indash DVD! you can check it out on my site, also just put up a new forum, just click on the link below...or go directly to my car at:
click here
click here
Since you've got a 91Z, you've already got a once piece RMS engine. That means you can use a STOCK LT1 flywheel. Grab the LT4 pressure plate and McLeod disc if you want a good clutch for not a ton of $$$.
You'll also need a dakota digital box (SGI-5) from www.dakotadigital.com to make your speedometer work with the new transmission.
I think everything else has been covered.
86IROC112
Sep 7, 2015 01:37 PM
rsrmoore
Aug 7, 2015 08:44 PM
