TC Lockup switch
Old May 2, 2002 | 11:48 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
TC Lockup switch
I am thinking about installing a lockup switch on my car. I know this may sound really stupid but how do you use it? I know flip the switch (sorry I just know someone would have said to flip the switch). What I mean is when do you engage and disengage the switch?
Old May 3, 2002 | 12:41 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Anyone? If nobody knows or has one can you point me in the direction of someone who does?
Old May 3, 2002 | 10:17 PM
TS b4c's Avatar
From what I have read you can turn it on at any time becuase the TC will not lock up in first no matter what. It makes for some real hard shifts but it will break stuff realy quickly if you continuosly us it. You may pick up a .1 in the quater.
Old May 4, 2002 | 11:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Go to www.smokemup.com/
That guy has the best/cheapest/most detailed setup Ive found.
Old May 4, 2002 | 11:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I'll do a bit more work since Ive got nothing better to do.
http://www.smokemup.com/tech/transmi...00r4/700r4.cfm
Enjoy.
SSC
Old May 5, 2002 | 07:09 PM
82camaro's Avatar
Car: 82 camaro SC
I would skip the brake switch setup. The aftermarket TCI kit doesn't use anything with the brake switch. As you slow down the tranny will continue to downshift until it's first gear, where the converter can never be locked anyway. The simpliest way would be to find the ground that goes to the tranny and put a switch on it so that when the switch was on the wire is grounded to good ground bolt under the dash. The 700r4's I've seen have a constant 12V to the tranny when the ignition is on and the ground is switched on and off by the computer or other means.
seiplentz
Aug 19, 2019 06:02 PM
Veaceonee
Sep 29, 2016 08:15 PM
customblackbird
Oct 1, 2015 04:30 PM
RacerM
Sep 28, 2015 04:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
