Th 350
Old May 4, 2002 | 07:19 PM
THE SANDMAN's Avatar
Car: 1983 Camaro
Engine: 5.7
Th 350
I am installing a TH 350 in my Trans Am. I bolted down the bellhousing bolts and went to do the crossmember and noticed that the stud on the mount is way off from the slot in the center of the crossmember. Is that normal, if not what should I do?
Old May 4, 2002 | 07:51 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
they make a bracket that is about 80 bucks in jegs that will cure that. it is a 700r4-th350 change. their is a mounting difference in the torque arm or something like that. the bracket fixes that problem.
Old May 5, 2002 | 06:45 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
U need to go to the junkyard & find a 82-84 camaro/firebird with the V6 & 3 speed 200metric trans. This car has the correct crossmember for your conversion. If u look under your car there's two sets of holes for mounting crossmembers. Buy the crossmem from the yard & be happy!
PS: dont for get the 3speed console from the donor car!
njdaewoo
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
