SLP POSI on stock rear?
Old May 14, 2002 | 11:16 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Can I put a SLP POSI takeoff unit on my stock rear on my 92 RS ar do I need different spline axles?
Old May 15, 2002 | 12:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What gears do you have now? If you have 2.73s, you'll need different gears. SLP posis are for 3.23 and up gears, better known as 3 series.
To answer your question, yes it will fit. You already have 28 spline axles.
Old May 15, 2002 | 01:07 AM
Car: 92' RS
Engine: LO3
I do have 2.73's but I want to get 3.43 or 3.73 installed at the same time. So will I need a ne carrier?
Old May 15, 2002 | 02:15 AM
vjo90RS8's Avatar
Car: 2002 Z28
the SLP posi unit is the new carrier. I have a 90 RS with 2.73s, and within the next month or two, im plaining on installing my SLP posi and Richmond 3.73s. Just remember you also need an installation kit that runs around $100-120. IM probably gonna go with the Deluxe Ratech kit that runs 120 in summit.
Old May 15, 2002 | 04:14 AM
mcconahay37's Avatar
A little confusion here. I've read mixed answers on which cars got 28 spline axles. Some say 89 and up got em. Others say 89 and earlier don't have them. So which is it? Or do some 89s have them and some not? reason I'm asking is because my friend has an 89 RS, and we're trying to figre out what mods we want to do to it for he best bang for the buck. The SLP posi and some 3.42 gears are high on our list, but if he has to swap axles we have a problem.
Old May 15, 2002 | 08:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With a 89 car, you never know. 88 was 26 spline for sure, most 90s are 28; but 89 is a mixture. There seem to be more 26s than 28s from people's posts here.
Definitely look before spending money.
Old May 15, 2002 | 11:33 AM
What do we do to figure out if it's 26 or 28 spline?
Old May 15, 2002 | 02:13 PM
vjo90RS8's Avatar
Car: 2002 Z28
I would like to know too, i have a 90 RS so i should have the 28 spline rear but this post is getting me kind of paranoid.
Old May 15, 2002 | 04:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Pop (well, unbolt, you know what I mean) the rear cover, remove the pinion shaft lock bolt, remove the pinion shaft, remove a c-clip from an axleshaft, and take the axleshaft out. I don't think the axleshaft splines are visible unless you take 'em out.
Old May 15, 2002 | 04:27 PM
89ROC's Avatar
yup...take an axle out and count the splines.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
