I Need A New Transmission????
Old May 20, 2002 | 02:49 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
WELL I JUST GOT THIS CAR OF MY BROTHER AND I NEED A TRANSMISSION AND I DON'T KNOW IF I SHOULD STAY WHIT THE 700R4 THAT I HAVE OR IF I SHOULD GO WITH THE 350TURBO? I WAS ALSO THINKING ABOUT TRYING TO CONVERT INTO A MANUAL BUT I AM NOT SURE HOW HARD THAT WOULD BE OR HOW MUCH IT WOULD COST SO IF ANY BODY HAS ANY TIP'S OR SUGGESTIONS LET ME KNOW THANK'S
Old May 20, 2002 | 03:26 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I would stay with the 700r4 or a T5 mainly because if I'm not mistaken the turbo350 doesn't have an OD, and the 700r4 is pretty much better. If you decide to stay with an auto and get a used 700r4, DON'T get any 700r4's from early years "84-89" mainly because the 700r4 improved over the years and got better, the earlier ones are crap, go for a later one.
Swaping from a automatic to a manual is pretty simple as long as you have the stuff required for the swap, I think there is a tech article... ah here it is:
https://www.thirdgen.org/newdesign/t...nualswap.shtml
That should tell ya everything you need for the swap.
Also you might be interested in a T56 manual tranny "came in 350's"
Old May 20, 2002 | 04:53 PM
Brad's Avatar
Exactly what does a transmission have to do with swapping engines? Moving to the appropriate forum. Please, take the time to actually read the forum name and description before posting.
Old May 21, 2002 | 06:34 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
ok the trans from 87 and on got better and um a 700r4 is better than a TH350? maybe for highway driving but for strenght and track use i'd go with a TH350 anyday
Old May 21, 2002 | 09:11 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
oops
Old May 21, 2002 | 09:23 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Originally posted by ir0cz
If you would actually READ his post, you would see that there was no mention of a motor or motor swap....350 tranny....not 350 motor
maybe if YOU READ what Brad said you'd put 2 and 2 together and realize this thread was orginally posted on the motor swap board sorry i had to heheh
Old May 21, 2002 | 09:35 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
My bad....guess I deserved that flame...no hard feelings. Sorry brad, my mistake.
Old May 22, 2002 | 03:55 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I love how a th700 plants your a$$ to the seat in 1st gear. OD is nice too. You'll be happier w/ a 700. Besides if you swap to a TH 350 you'll get a shorter 1st gear and closer spaced gear ratio's for all around driving but you'll lose OD and you have to get a different driveshaft. I believe the 350 is longer than a 700, or vice versa.
Old May 23, 2002 | 11:06 AM
Pro Built Automatics's Avatar
If you need a Street/Strip 700R4 (that will last, & comes with a one year warranty) then give me a call! 800 7763288 M-S 10-6 PST. If you get a chance, check out my web site at www.pro-built.net and you will see exactly what I do to these 700R4's. Let me know?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
