Things that go bump in the night.
Old May 28, 2002 | 08:29 PM
Hung Start67's Avatar
Ok guys..here goes...92 z-28 46,000 miles..mods are borla exhaust..and hyper tech thermo-master chip..ok..when i put the pedal to the metal..and the 700r4 shifts from first to second..i get a nice big thud...sounds like from underneath the passenger floor pan..could it be...the cat's banging the floor board? torque arm? tranny mount? u-joints? gonna check it out this weekend just wanted to get some opinion's..thanks guys later.
Old May 28, 2002 | 08:41 PM
ede's Avatar
ede
check your trans mount, i bet it's broke. replace it with a ES poly mount and you'll never have to worry about it again
Old May 29, 2002 | 06:01 PM
found the problem
yep...tranny mount is messed up..just ordered one from summit racing...poly unit...$20.95.
Old May 29, 2002 | 08:01 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I am starting to have the same problem. It makes a big thump when it shifts. Is the tranny mount easy to see if it is broke? Thanks for any help you can give.
Brian
Old May 30, 2002 | 04:13 PM
ede's Avatar
ede
if i was going ot the trouble to get under the car to look i'd just replace it with a ES poly mount. not hard to do
Old May 31, 2002 | 01:16 PM
Akshay's Avatar
check the u-joint and trans. fluid juuuuuuust incase.
Akshay
1989 RS 2.8 5-spd.
Old May 31, 2002 | 03:56 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Checking the trans mount is easy.
1. Get the car off the ground. I like Rhino Ramps for this kind of work.
2. Remove the single nut holding the trans mount to the crossmember.
3. Place your jack under the transmission pan.
4. Using a large block of wood to distruibute the force of the jack, gently start lifting the transmission.
5. Once the weight is off of the trans mount, you should be able to see large cracks in the rubber bushing. Pieces of this may fall out. If this is not the case, you are now two bolts and 5 minutes away from a full R&R of the transmission mount anyway, so:
6. Get off your cheap, lazy butt and call Summit for the ES poly mount.
7. Install new poly mount, lower car and enjoy new, tighter feeling driveline.
Old Jun 2, 2002 | 11:27 AM
82Trans Man's Avatar
Brian
Put a pry bar between the crossmember and the transmission and pry upwards my transmission snapped the rubber right off the metal so I put a mount from a caprice (autozone) in it they are solid metal just a thought.
TheJoeY88
Dec 31, 2016 07:30 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
