will my gears stop humming???
Old May 29, 2002 | 10:12 PM
jordanz28ss's Avatar
I just put new gears and posi in and it humms at certain rpm's...I have been told that it will do this during break in time. Is this suppose to happen or not?
Old May 30, 2002 | 04:42 AM
ede's Avatar
ede
are they richmonds? if so they tend to hum, richmonds are cut a little differant for increased strength and that causes them to make more noise.
Old May 30, 2002 | 05:46 AM
Yup they are richmonds
Old May 30, 2002 | 08:52 AM
82camaro's Avatar
Car: 82 camaro SC
Gear noise very, very rarely gets quieter with time. The sound will stay the same. If you do have a problem with the gear set-up, the noise will get worse.
Old May 30, 2002 | 11:38 AM
urbman's Avatar
Just so that you are sure...
Purchase some friction modifier. Bring it with you
when you have the gear lube changed (after break in).
A fair number of "trained" lube shop techs are "taught"
that you don't need it with "whatever the hell it is gear lube"
that they use. Make sure they add the friction modifier.
Old May 30, 2002 | 03:11 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Richmonds are always noisy, even when set correctly.
Old May 30, 2002 | 03:41 PM
thanks for your help guys...I will be sure to change the gear oil and and the friction stuff in a few weeks:lala:
jklein337
Sep 19, 2018 06:23 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
IROCtometal
Sep 20, 2015 11:08 PM
86White_T/A305
Aug 17, 2015 12:16 AM
