LS1 driveshaft????
Old May 31, 2002 | 12:10 AM
Kandied91z's Avatar
LS1 driveshaft????
are they a direct bolt in to my 700-r4 and is it worth it to me to upgrade or change?
i'm running roughly around 300 with the ocasional 100 shot.
also, what should i expect to pay for a used one?
Old May 31, 2002 | 12:38 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
As I understand it, YES they swap right in. Look at this rebuild in progress:
http://www.cardomain.com/member_page...=205049&page=7
As stated on his site, he got it from Dal and it was $245 new. I've seen used ones go for anywhere from $125-225 usually. That thing is massive!!
Check www.camaroz28.com too for used ones.
Ed
Old May 31, 2002 | 01:40 AM
Kandied91z's Avatar
what advantages and disadvantages would there be???
Old May 31, 2002 | 10:25 PM
kevinc's Avatar
Car: 1982 Z28
Advantages: it's light, well balanced, and designed for a lot more hp and torque than your average 3rd gen makes.
Disadvantages: it's so big in diameter getting to the rear u-joint strap bolts is a pain. Can't get a socket on, have to use a wrench. May not be as strong as the smaller-diameter 4th gen 1LE aluminum driveshaft, no conclusive data tho.
Old Jun 1, 2002 | 08:32 PM
Kandied91z's Avatar
so there are 2 types of 4thgen aluminum driveshafts???
if there is how can you tell the difference? what models have the better version?
Old Jun 1, 2002 | 09:34 PM
kevinc's Avatar
Car: 1982 Z28
1LE shaft is smaller diameter than the LS1 piece.
Old Jun 2, 2002 | 03:06 PM
Kandied91z's Avatar
so your talking about 1-le for our cars and the standard aluminum used on the ls1's.........so there is only one aluminum found on 4thgen right ?
Old Jun 2, 2002 | 05:51 PM
kevinc's Avatar
Car: 1982 Z28
Both are 4th gen pieces. The 1LE part is for LT1 cars, the LS1 is for...well, you get it.
Old Jun 3, 2002 | 12:33 AM
Kandied91z's Avatar
gotcha
is their any real weight difference?
Old Jun 3, 2002 | 10:52 AM
Momar's Avatar
how do the thirdgen aluminum drive shafts compare?
Ben
Old Jun 16, 2002 | 11:05 AM
woody86's Avatar
will they fit with a TH-350 or would i have to get a new yolk? what about the length?
Old Jun 16, 2002 | 07:30 PM
Z28DJP1987's Avatar
The 1LE shaft is the sams part number for 3rd & 4th gen cars, 10085375.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
