91 350 TPI mated to a late 60's Saginaw 3 speed.....what bellhousing will fit?
Old Jun 2, 2002 | 09:42 PM
chuddy117's Avatar
Well, the title pretty much says it all. Are all 350 bolt patterns the same? Will any bellhousing work for this tranny? Its the standard 4 bolt mount with the 4 ears that bolt to the bell. Thanks guys.
Chad
Old Jun 2, 2002 | 09:45 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: 91 350 TPI mated to a late 60's Saginaw 3 speed.....what bellhousing will fit?
Originally posted by chuddy117
Are all 350 bolt patterns the same? Chad
yes all small-block chevy bolt patterns are the same
Old Jun 2, 2002 | 11:01 PM
Jester's Avatar
You'll need a bellhousing from an 82-83 car, or an aftermarket one. In 84-up thirdgens, trans end of the bellhousing has a 15 degree tilt to it that won't work with an old tranny.
could probably use a older than 82 bell housing...but I believe the clutch provisions are different. I don't know what it takes to work.
Old Jun 3, 2002 | 05:18 PM
chuddy117's Avatar
Hey guys, actually, I'm puttin this motor in my '55 chevy, so I don't think i'll need a special bell, then. Thanks a lot guys.
Chad
383backinblack
Aug 15, 2015 06:36 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
