Problems after transgo install
Old Jun 3, 2002 | 09:56 PM
chevyguy3's Avatar
just wondering if any of you guys might have any idea what is wrong here. did the transgo, and now 1st gear works fine, but it wont shift to 2nd until you let off the gas, and then just spins/coasts freely like you are in neutral unless you rev it up high and then it grabs, but if you let off goes back down to idle and coasts. there is no 3rd/4th at all. manually downshifts to 1st fine. removed some washers from the servo, didnt change things at all. swapped back to the stock servo setup, and still no change at all, so i doubt its anything having to do with that. fluid has definitly been full, and TV is working properly. i have done 3 shift kits before without any problems (none of them were transgo's though). after watching the whole video again and looking over the instructions i cant see where i did anything wrong, but obviously i messed up somewhere. any ideas? thanks guys
Old Jun 4, 2002 | 06:31 PM
Pro Built Automatics's Avatar
Give me a call at 800 7763288, ok?
Old Jun 4, 2002 | 07:38 PM
chevyguy3's Avatar
thanks for the offer. i just found a problem in the valvebody that im sure is probably it. if i still have problems after i finish putting it together here in a minute ill give you a call. thanks
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
