after 305 to350 swap trans prob.
Old Jun 5, 2002 | 06:53 PM
88NOSTA's Avatar
i cant get the linkage to line back up i need like 2 inches more cable when i put the trans in park and the shifter in park it wont work.
Old Jun 15, 2002 | 02:49 PM
88NOSTA's Avatar
help me help me
Old Jun 16, 2002 | 03:19 PM
bradkeith's Avatar
Are you using the same transmission?, the cable can be adjusted on the transmission, but in your case it shouldn't need 2 more inches. Maybe your cable is caught on something?
Old Jun 16, 2002 | 08:40 PM
88NOSTA's Avatar
yeah it's the same trans same cable and it's freed up
Old Jun 26, 2002 | 08:53 PM
88NOSTA's Avatar
has anyone had this prob. befor
Old Jun 28, 2002 | 06:37 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Have you figured it out yet....there really should be no difference between the 2 motors...they are the same on the outside....
Old Jul 3, 2002 | 07:08 PM
88NOSTA's Avatar
no still cant get it. i dont know what's up with it that is the only prob. stoping me for a test drive from the 305 to 350 swap useing the same heads and tbi. and the 2 inch is more like 8th of a inch sorry
Old Jul 3, 2002 | 11:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like you need to adjust the nut on the housing little bit. Not sure why it would have changed with just an engine swap, but you don't need a new cable.
Old Jul 4, 2002 | 11:26 AM
88NOSTA's Avatar
what nut do it adjust? the one the the cable hook's to is sloted any go's one way
Old Jul 15, 2002 | 11:17 AM
stock sux's Avatar
i had the same problem when i went from a 305 to a 350 and i changed my shift cable. its going to sound stupid but check and see which way you installed the cable and bolt. if the bolt is facing out ward it makes it just a little to short for it to click into park just flip it over on the shifter on the transmission and this should give you that little extra.
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
