Clutch problem still!
Old Jun 6, 2002 | 11:04 PM
D_White_Devil's Avatar
(Original Post)"1989 305 tpi (F engine) 5 spd. 77mm tran.
Just installed new clutch, pressure plate(clutch kit), lowered vehicle went to back it out from lift and extremely rough shifting almost no reverse shifting. Flywheel was machined to take out high spots, double check tranny install,etc..
I think problem is in hydralic linkage(master cylinder, slave cylinder). Anyone have this problem?"
(Update): Installed new clutch master and slave cylinder, still problem occurs. I think it could be pressure plate or throwout bearing, also the plastic guide tab on end of slave cylinder has not snaped (which is supposed to)while clutch pedal has been pumped(maybe due to defective pressure plate or throwout bearing?) Any help please I need this car for work ASAP. I have tried every thing else. Thank you.
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
