busted my 7.5, heard about 9" having alot of vibration problems in f'body's help me.
Old Jun 10, 2002 | 02:01 PM
zboss86's Avatar
I just shattered my 7.5 rearend...
I'm broke going to school this semester... won't be able to afford a great rear end till next semester...
I've heard of people welding up the rear end in 7.5's and putting good gears in them to make them hold up. How well will this hold up untill it breaks an axle,
I'm just running drag radials right now...
While I get it fixed temporarly, I'm checking on aftermarket rearends. I got a guy going to give me a buddy deal on a new aftermarket 9" center section with axels, studs, and housing, used junk yard center section for about $900.
Now I know this is a decent buy...
I've heard of 9" having alot of vibration in f'bodys b/c of the 9" having an offset drive shaft...
Can any body verify this?
thanks,
Shad Haynes
(ZBOSS)
check out my site in my signature...
Old Jun 10, 2002 | 02:06 PM
zboss86's Avatar
website
the one in my signature seems not to be working,
try this one...
http://camaroz28.cardomain.com/id/425395109
Old Jun 10, 2002 | 03:44 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I've heard of that too but I've never had a problem with vibes. I'd just make sure the pinion angle is correct especially with aftermarket torque arm. I'm not sure what my pinion angle is at because I still have the stock torque arm. I never bothered to check cuz I didn't have any probs with it. BTW I'm using a Moser 9" housing and a 3.5" aluminum driveshaft with spicer U joints.
Old Jun 11, 2002 | 09:20 AM
zboss86's Avatar
appreciate the reply,
fact or fiction:
I've heard the 12 bolt rears are alittle easier to turn than the 9 bolts, anybody ever heard about that...
anybody else heard or had problems with the 9" vibrating
Old Jun 11, 2002 | 09:29 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Stock or Factory 9" ford rears ARE harder to turn then Stock or factory GM 12 bolts, the reason why is because the pinion is much farther down the ring gear in the 9"...
I don't know of even one aftermarket 9" rear that hasn't had this problem corrected so it shouldn't be too much of a concern!
Here is an article:
12 VS 9
Old Jun 12, 2002 | 09:34 AM
zboss86's Avatar
thanks for the reply
anybody else on the vibration problem...
Old Jun 12, 2002 | 06:29 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Vibration can be a problem, but it is soley related to driveline angle both at the trans end & the rear end. This can be corrected with an adjustable torque arm, such as Spohn's. The trans can be shimmed up or or down to correct as well.
Old Jun 12, 2002 | 06:43 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
Mini-spool !!!!! Get an open diff., pop in a mini-spool, add your gear, POOF!!!!, problem solved. I never ran one in a 7.5 though. I ran a mini-spool in both my 9 inches and never had a problem, even with slicks on the street. Just don't whip around corners. It will give you back your ride to thrash on until you can afford King Daddy !!!!
hectre13
Aug 26, 2015 08:17 AM
db057
Aug 22, 2015 08:17 PM
sreZ28
Aug 14, 2015 07:48 PM
gta power
Aug 13, 2015 06:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
