373 or 308
Old Jun 18, 2002 | 10:29 AM
Tranny89's Avatar
Car: 89 Trans-AM
Transmission: 5 Sp.
373 or 308
Can anyone help. I have an 89 TA with a 10 bolt 308 rear. It is a 5-speed. Would it be benefit me to put 373's in.
Old Jun 18, 2002 | 10:58 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i'd go with 3.42's for daily driving with a 2.95 first gear ratio(t-5) it still gives you good launches and decent gas mileage...............
Old Jun 18, 2002 | 12:44 PM
ATOMonkey's Avatar
Definately get gears if you ever have the option.
Old Jun 18, 2002 | 01:41 PM
Guido's Avatar
Car: 2000 Trans Am
Wrong forum. Moving to drivetrain.
Old Jun 18, 2002 | 05:03 PM
iroc22's Avatar
3.42's work better with 5-speeds.
Old Jun 18, 2002 | 06:19 PM
Slade1's Avatar
I would go with no less than a 3.23 at bare minimum for performance applications. If you have a stick a 3.42 is a good choice, where a 3.23 is good for an auto but 3.42's either way don't hurt for either. 3.73 is fairly high and as long as you can live with the gas guzzling not a major loss as as a 4.10.
Old Jun 18, 2002 | 09:40 PM
nitrobreth's Avatar
i got 4.10's talk about acceleration. oh, i'm usng a six-speed though. gas mileage is still pretty horrible
Old Jun 18, 2002 | 09:46 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
I'm running 3.73s with a 700R4 overdrive auto and its awesome - about 2600 rpm on the highway doing around 70mph. I'm planning on a 5-speed soon too which should bring my cruise rpm down. The 5-speeds came with 3.08s stock and the auto's came with 2.73s (i'm talking low-perf. models) so that reflects a little where the ratios sit.
tyler
Old Jun 19, 2002 | 08:27 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would not go with 3:73s on a stock TPI for 1/4 gains. 3:42s would be better. But if you plan for mods later on for higher rpm breathing, then go for the 3:73s now, so you don't waste your money.
Old Jun 19, 2002 | 08:42 AM
Tranny89's Avatar
Car: 89 Trans-AM
Transmission: 5 Sp.
ok thanks guys for the info.
i think i'll go for the 342's
i think that came stock on some GTA's correct.
or it was the borg warner option??
Old Jun 19, 2002 | 01:36 PM
iroc22's Avatar
With the G92 you could get the 3.45:1 BW rear with the 5-speed.
Old Jun 22, 2002 | 10:07 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i also have 3.73 and 700r4 around 2600rpm around 60 or 65, uses about 1/8 tank in about 25 miles, thats not bad at all to me whatsoever, im used to older trucks, so,,,, and the 67-72 came std with 3.73, so yay... 3.73 is my gear
good luck with whatever you do.
Old Jun 22, 2002 | 11:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
would a 3.42 be good for my setup? [check sig]
I am assuming u can get the 3.42 in a posi setup???
what if any cars came with one?
I would like to upgrade my rear end but fas as I know only thing that come in a thrdgen in posi was the 3.73?
A easy junkyard swap is what I am looking for.
Old Jun 23, 2002 | 07:28 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
alot of the v-6 cars came with 3.42's..some posi
Old Jun 23, 2002 | 08:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
sweet, anyone know what years and/or models had the 3.42 posi???
Old Jun 23, 2002 | 10:06 PM
Engine: 406
89 RS...,,,check the thirdgen technical area...that will help ya
Old Jun 23, 2002 | 11:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The tech info is not very clear. It does not say posi or not, unless (G92) means posi??? Also they do not have all the models year and engines size info. For 86 they do not have info on the 2.8 bird.
I would like an easy swap 3.42 posi into my bird.
Old Jun 23, 2002 | 11:46 PM
iroc22's Avatar
G80 should be the posi RPO and G92 was the performance axle ratio package, that actually was more of a 'performance package'.
Old Jun 24, 2002 | 07:17 AM
Engine: 406
exactly what I have in mine..why the put there performance package in the v-6 is beyond me, but I'm glad they did...
Old Jun 24, 2002 | 04:23 PM
Pro Built Automatics's Avatar
For long clutch life, you need a minimum of a 10 to 1 first gear ratio. 2.95 x 3.42 = 10.09. 2.95 x 3.73 = 11.00. If you have a choice of transmission gear ratios, then have the biggest spread between 1st & 2nd with each gear thereafter getting closer till you reach 1 to 1 (direct). This has worked very well in the past, when I did ST-10's, Muncies, T-10's & others when trying to achieve long clutch life, better et's, & more mph in the quarter mile. I hope this helps some!
Old Jun 25, 2002 | 03:21 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
anyone know off hand what year n models had or came with the 3.42 in the v6 package.
like i said the tech info section is no help, as it does not state posi or not and it does not have the v6 info for every year.
:rockon: SLAYER :rockon:
Old Jun 25, 2002 | 12:53 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
man i have 3.73's in my L69 car with a stick and it still gets decent mpg on the highway (23) and thats at 75-80 mph
and it launches like a mother
1nastygta
Oct 28, 2015 08:51 PM
beastin91rs
Oct 9, 2015 07:38 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
bad camaro RS
Aftermarket Product Review
Jan 21, 2001 08:42 AM
bad camaro RS
Sep 23, 2000 07:46 PM
