Mobil 1 ATF - Is it Crap ???
Old Jun 19, 2002 | 01:09 AM
92GTA's Avatar
I put this stuff in my tranny about 3 months ago and ever since it slips going into gears!!!!!!! WTF!!!!! My tranny was PERFECT before the switch, I could damn near chirp it into 3rd!!!!!!
Is this Mobil 1 ATF total crap or what?????
I just bought some Royal Purple ATF but is it too late to save my tranny from the damage that the ****ty Mobil 1 did????
Old Jun 19, 2002 | 07:15 AM
ede's Avatar
ede
all i use is mobil1 without any problems, in manuals and autos, even the race car is full of it, maybe you have other problems and it's not the oil you're running
Old Jun 19, 2002 | 11:40 AM
Intercepter's Avatar
I also use Mobil1 synth. ATF and have had no problems.
Old Jun 19, 2002 | 12:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pro Built doesn't like the Mobil 1 ATF based on test data and experience.
I know a guy out here that went through 2 TH400's and a 'Glide last season using it (it's a high 10-sec big block '83 Monte, that may have something to do with it).
AMSOIL, Redline seem to be the preferred synthetic ATFs. I haven't heard enough about Royal Purple to say anything about it.
Old Jun 19, 2002 | 03:04 PM
AggieZ28's Avatar
Mobil one is pretty good. My car has always run of synthetic stuff. IT runs good and is still stock.
NO problems with mobil.
Old Jun 19, 2002 | 04:16 PM
IROCZ88's Avatar
Five7kid you are full of crap. I just bought an installed a tranny from pro-built and regular Mobil (non-synthetic) atf is what Dana recommended along with his pro-fluid that he sends.
Old Jun 19, 2002 | 06:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
IROCZ88, 5.7kid did not say Mobil ATF he said "Mobil 1" full syn ATF is what Danna doesent like.
92GTA, If you serviced the transmission when you swiched oil it's quite possible the filter was installed incorrectly or the filter housing is cracked. That would cause the problems your having.
Old Jun 19, 2002 | 08:16 PM
ede's Avatar
ede
irocz88 i think it's time to remove foot from mouth
Old Jun 19, 2002 | 09:38 PM
IROCZ88's Avatar
Sorry, I misread it.
Old Jun 20, 2002 | 04:37 AM
ronterry's Avatar
Car: '94 Corvette
The only thing I picked up from switching to synthetic ATF was a leak (Kinda of expected that), outside of that no problems.
BTW: Been leaking for about 15,000 miles now (*ucking no room to work under a Vette !!!).
Now that I think about it, I might address that this weekend ?
Ron
Old Jun 20, 2002 | 01:43 PM
camaro6spd's Avatar
fivesevenkid is really bent on his amsoil....preaches about the 25k mile change intervals everytime he gets and puts down all other oils...someone is becoming brand specific
Old Jun 20, 2002 | 03:42 PM
five7kid's Avatar
One of the rules in my house is, "If you have something good, share it." I have some good information, and I'm sharing it.
I'm so brand-specific and bent on putting down other oils, however, that I mentioned a couple of other brands. Shame on me.
ronterry, what brand did you switch to? Any idea where your leak is? Was the leak a result of the act of switching, or what was put in? I have 5 vehicles with AMSOIL ATF in them, and they don't leak. One of the Bonnevilles leaked at first, turned out to be loose converter cover bolts left that way by the rebuilder used by the previous owner. Hardly a result of using synthetic.
Old Jun 20, 2002 | 04:00 PM
IROCZ88's Avatar
Amsoil is really good atf, just too expensive for me. A case of regular mobil is only $20 and Dana claims it's good ****. I think Amsoil is around $75 for 2.5 gallons. OUCH!!!!
Old Jun 20, 2002 | 04:44 PM
ronterry's Avatar
Car: '94 Corvette
It was Mobile One. I'm now using durablend.
I swear the day after it started leaking around where the VSS is.
Not ruling anything out, it could be the pan from the change. But I changed the oil since, and the same amount leaks. It's not a big leak, but over a month it leaks about a cup or so.
Ron
Old Jun 20, 2002 | 06:08 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I am getting new tranny and do not want to change from brand to brand what do you guys think is the ALTIMATE ATF?
Old Jun 20, 2002 | 09:43 PM
poncho9789's Avatar
Amsoil useually runs (from what I have seen and our prices at work) about $1 higher per quart. For me that isn't enough to whine and cry about when I am already spending so much on oil anyways.
Old Jun 22, 2002 | 10:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what are the big advantages of synthetic over regular and has anyone ever had problems when using or swapping to redline ?
thanks
school boy
Oct 22, 2015 11:47 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Orr89RocZ
Sep 13, 2015 09:41 PM
