New Guy, Need Help
Old Jun 21, 2002 | 03:17 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
New Guy, Need Help
I bought a 91 camero rs this week, and I need some tips/ideas. It has the 700r4 auto tranny, and it does not have the high gear (overdrive) when it shifts into it, its like its in neutral. Does this have to be rebuilt, or is thier some lever, vacume, spring, or something I can do myself to fix this. I have mech ability, just dont work on trannys to much.
Old Jun 21, 2002 | 03:41 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there "new guy". Welcome to the boards.Let's get you off on the right foot, shall we??
CAMARO, with an "A"
Do a good check on the vacuum hoses. To check for leaks, spray a little carb cleaner around the connections and if the engine revs a bit, you have a leak. It just might not be adjusted right either. How many miles on the car? Indeed, maybe the trans is gone.
Where are you? I'm originally from Harrison on US 65, by the way....PIG SOOIE!!
Old Jun 21, 2002 | 04:22 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Mmmm......
Strange situation for a rare "CAMERO" car.
Try with a lot of possible adjusts. If not , a rebuilt must be considered.
Regards,
Denis.
Old Jun 21, 2002 | 10:11 PM
Dale's Avatar
Engine: 350 S-TPI
Replys
Thanks for the replys, Right now the car wont start, I'm going buy what the prev owner said. Onces it starts (hopefully this weekend) I will be checking hoses, etc. The car has 165000 miles on it. I am from central Arkansas. Hope this helps, any other suggestions??
Old Jun 23, 2002 | 10:28 AM
Dale's Avatar
Engine: 350 S-TPI
Got it running
Got it running yesterday and drove it home. It will shift into the gear just I have to floor it to make it go in that gear. It does have some vacume leaks due to the break booster leaking, and some hoses do look quite dry rotted. Will take it for a spin after I get that stuff fixed. A counter tech said that their is a overdrive sensor in the tranny, and that could be bad. Is this true, if so, where is it at on the tranny? The repair book I have is not to helpful on the tranny. Baiscially, other then chainging fluid, take to a professional.
Old Jun 24, 2002 | 08:15 AM
Denis.V's Avatar
Axle/Gears: No idea
Overdrive sensor in a 91' tranny? I don't believe it.
Disassemble the tranny is the last, last step. At first, try with all the repairs and adjusts "around" the tranny (change the fluid and filter included. Fill the fluid at FULL mark, no "ADD", no at middle). It's the logical sequence.
Regards,
Denis V.
Old Jun 24, 2002 | 08:41 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks for the info dennis, will fix other repairs first.:hail:
Old Jun 24, 2002 | 10:30 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
and then adjust the TV cable like this...
Start here: To adjust the TV Cable skip the book method and do this: Press the 'D' shaped lock button on the adjuster and loosen the cable setting (The black housing that the metal cable is in will move forward). Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the 'D' button and pull the cable casing (the black tube) back as hard as you can (putting maximum tension on the metal cable) and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable casing so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does. Per TRansfixLeo
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
