What size gears do I have???
Old Jul 7, 2002 | 08:48 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I have a set of 3.08's from an 85 or 86 formula and I need to know what size the ring gear is. Do any of you know. I need to replace the gears because I have ruined them but I don't know what size carrier I have.
Any help would be great.
Old Jul 7, 2002 | 08:55 PM
Momar's Avatar
How many bolts are on the cover? If it is 10, it is 7.5". If it is 9 it is a 7.75 borg warner rear. The borg warner is a lot stronger, but parts are quite a bit more expensive also.
Ben
Old Jul 7, 2002 | 09:01 PM
it is a 10 bolt. Are you sure that the gear can't be an 8.25 or 8.5.
Did they all come with a 7.5??
The donor car was auto 4 speed with an injected 305. It is posi too.
Old Jul 7, 2002 | 09:27 PM
there is an auction ending in less than an hour. It is for an 8.5" 3.73 set, never been used. Will it work for me??
I need to know what size the carrier or the gears that I have are.
The formula that the gears came from had rear drums, so it shouldn't have had the borg warner rear end right?
please respond with anything... time is ticking..
Old Jul 7, 2002 | 09:50 PM
please help me...
what size are the gears??
the auction is ending soon. what size do I have??
Old Jul 7, 2002 | 09:51 PM
Momar's Avatar
no, all thirdgens had the 7.5 or 7.65, and the 7.65 didnt hapen till around 89 or 90.
Ben
Old Jul 7, 2002 | 09:52 PM
thank you very much...
Old Jul 7, 2002 | 09:53 PM
Momar's Avatar
Oh, and with drums it shouldnt be a borg warner but wierd **** happens. I had a 3.08 drum borg warner rear out of a 85 T/A.
Old Jul 7, 2002 | 09:59 PM
But there is no way to have a borg in a 10 bolt pumpkin, is there?
The guys that installed the posi from the formula into my t/a might have kept my original pumpkin in there.
Old Jul 7, 2002 | 10:32 PM
Momar's Avatar
nope. If there is 10 bolts it is all 10 bolt if there is 9 it is all borg warner.
Ben
Old Sep 9, 2002 | 11:05 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
i have an 86 T/A with a 9 bolt borg warner, was wondering if that came stock in 86? Along with what size axles it has?
Old Sep 10, 2002 | 07:25 AM
Momar's Avatar
Yes, they came stock from 85 89 and maybe some in 90. They have 28 spline axles.
Ben
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
