700r4 Problems
Old Jul 8, 2002 | 09:51 PM
goosejg73's Avatar
700r4 Problems
Well, I think that my trans is toast... It won't shift from 1'st to 2'nd till at least 4500 rpm, then once in second, it doesn't go back into first. It slips in the shift from 2'nd to 3rd, and od works as normal. The tv cable is not the problem. I have adjusted it to no avail. I cleaned the governor, and that didn't help. I changed the fluid and filter to find burnt fluid and metal in the bottom of the pan.
Any ideas???
Old Jul 9, 2002 | 02:52 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If there is metal in the pan then there is metal in the valve body.
One or more of the valves is hanging up.
Pull down the valve body and remove each valve one at a time and clean with brake cleaner. Do not use rags or paper towels to wipe the parts as the lint can cause the valves to stick. Just use brake cleaner and air. You can buy a pair (2 sets) of valve body gaskets and a pan gasket from GM at reasonable cost. A transgo shift kit, even the SK700 jr and a corvette servo and boost valve will tighten up those shifts.
If you are not installing a shift kit, download the instructions off the net for one, so you can see where the ***** go back in.
I think TCI and B&M has online instructions for their kits.
You can use a little Vasoline to hold the ***** up in the trans while u reinstall the valve body and plate with new gaskets.
Old Jul 9, 2002 | 06:33 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Re: 700r4 Problems
Any ideas???
Metal in the pan & burnt fluid = toasted trans. Don't waste your time with a trans kit, you need an overhaul or another trans.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
