very early/soft shifts after intake/tranny cooler install WTF?
Old Jul 10, 2002 | 04:56 PM
TBI305Camaro's Avatar
ok i just installed a edelbrock TBI intake and a perma cool tranny cooler. i readjusted my TV cable and it didnt help much. at WOT it will not kick down like it used to and it will shift at about 3k or so. i have no power at all because the RPM go up very slowly. Im confident the intake was done properly because ive done it before without problems. i really think it has something to do with the position of the TBI on the intake. i noticed the edelbrock intake sits further back...whats up??
Old Jul 10, 2002 | 09:34 PM
Nordbert's Avatar
Adjust TV cable again. My friend's pickup acted the same-
soggy shifts and no kickdown. We set the cable as per
Transfixleo's instructions and the problem was gone
Old Jul 11, 2002 | 06:38 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Check your fluid level, as well as TV cable adjustment.
Old Jul 11, 2002 | 12:27 PM
i had to add about half a quart to it. i knew i would since i added the tranny cooler. i adjusted it to max tv like it says to do in my trans-go shift kit video. but with the pedal to the floor it wont go all the way to full throttle. the intake sits further back...i had to bend the fuel lines to get them to fit
Old Jul 12, 2002 | 12:40 AM
383 Smoka's Avatar
If its a new intake, did u make sure the guy put the right throttle linkage on it? Some of them (Edelbrock), need a special kickdown linkage for the 700R4's... This could be yer problem...
Old Jul 12, 2002 | 12:19 PM
uh I installed the intake. And why would i need a special linkage...i just changed the intake nothing else. Did come with a little package of stuff which i have no idea what its for.
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
