9 bolt expert needed!
Old Jul 16, 2002 | 11:19 PM
moore82nd's Avatar
I just got 373 gears for my 9 bolt to replace my 327 and i have never messed with rearend gears before. I need detailed instruction on how to put in the gears and install a bearing rebuild kit that i have also. Im not mechanicaly retarded so i can do it i just dont want to go into it blind. Any help will be greatly appreciated.
Old Jul 17, 2002 | 07:15 AM
ede's Avatar
ede
buy a manual first
then install the pinion with out the crush sleeve (if 9 bolts have one) set the pinion depth (it's etched on the pinion)
reinstall pinion with crush sleeve and set bearing preload
install carrier and set back lash then check the contact pattern.i'm betting you don't have any of the tools to do this with since it's pretty specialized. you'll need a in/lbs dial type torque wrench, depth mike, something to use as a datum surface to measure the pinion depth, mag base and indicator, "special tool" to hold the pinion yoke
Old Jul 17, 2002 | 03:29 PM
moore82nd's Avatar
hrmm maybe this is out of my league i have the tq wrench and depth mic but the other stuff i do not. How much would it cost to have it done and do you have any recomindations for any nationwide shops?
Old Jul 18, 2002 | 06:45 AM
ede's Avatar
ede
no idea what flat rate is on it, but i'd guess 3-4 hours. guess about all you can do is start making phone calls, no idea who or where you could take it ,maybe gm dealer but i doubt they'd do as good a job as someone who specializes in it.
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
