700r4 problem
Old Jul 17, 2002 | 12:57 AM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
700r4 problem
700r4 shifts fine when manual 1 ta 2 but when in drive or overdrive it will down shift and then the rpms will pull but then the tach revs like it jumps into neutral but its not then if i let off the gas then hit it again it works i have pulled my tv cable to correct it but then i worsens after a while then ill pull it out further and so on even sometimes in OD if i hit a certain rpm and speed at the same time the car will kinnda shake, i think its from the tv cable is messed up
is it my clutches goin bad and they just cant hold anymore if so how much is it to get them replaced will stronger ones and probably a new tv cable
please give info and opinions
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
