check ball madness
Old Jul 23, 2002 | 05:24 AM
Recluse's Avatar
check ball madness
Im trying to figure out how many check ***** Im supposed to have on the top side of the VB. I have ONE. Thats it. I have the video for rebuilding a 700r4 and the dude on the video said that ALL 700r4s will have at least TWO in the VB (he also shows the locations). Am I missing one? Somebodys been in the tranny before me and Im trying to determine if anything is amiss. Also I installed the police 3-4 valve this weekend and my 2-3 shift wants to slip before engaging. 1-2 is solid and 3-4 is solid. but 2-3 will slip badly if im steppin on it when it shifts. any thoughts? When I had the VB down could one or more of the checkballs above the separator plate come out or get misplaced? Ididnt remove the SP but it was not sitting flat on the case while the VB was out.
Old Jul 23, 2002 | 04:37 PM
Jay 727's Avatar
If you don't have a shift kit look here
http://www.transonline.com/electroPu...site/index.cfm
If you have a shift kit you have to go by their instructions.
Old Jul 23, 2002 | 08:14 PM
Crosley4's Avatar
in an 1988 & up valve body you can use only one check ball in the valve body casting.
THe video will show two,,,,, one near the front of the vb and one back a couple of inches. Always Install the one that is back a couple of inches.
The front one is a check ball for the over-run clutch pack application and can be left out.
Old Jul 24, 2002 | 04:42 AM
Pro Built Automatics's Avatar
If you are not running the Trans-Go Shift kit, use two in the valve body. With the Trans-Go Performance Shift kit, one near the front of the valve body.
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
