home made short throw shifter
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
as some may know i am putting a t5 in my car, i don't have the money to spend on a short throw, so could i just cut the factory shifter down so its not so long and get a similar advantage???
or would it not be worth my time
also if anyone has a stock flywheel to fit a 2 piece rear seal engine send me a message,
i am not having good luck with this, one got lost in the mail
, the second one i found, i got the money order back address unknown
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Cutting the shifter down doesn't make it a short throw shifter. To make a short throw shifter you need to raise the pivot point of the shifter. This way the bottom portion in the shift rails still moves the same distance but the top part that you grab onto moves a shorter distance.
Car: 1984 Firebird
Axle/Gears: 4.10
right i realize the pivot is different, it just seems to me that the shifter is gonna be stickin WAY up outta the console when i get this finished and i really don't want that, but i guess i'll live with it,
colton_carlson
Mar 8, 2019 12:21 PM
rsrmoore
Aug 7, 2015 08:44 PM
