PLEASE HELP Daily Driver GTA lost 3 & 4 gears
Old Aug 6, 2002 | 10:24 PM
MKerbouchard's Avatar
My car lost 3rd and 4th gear when I was driving home tonight. Transmission will kind of shift into third but slips, (seems like neutral), 1st and 2nd seem fine. Fluid did not boil over and reads full. Is the transmission toast or is there anything else that might be wrong? I really appreciate your help.
Old Aug 6, 2002 | 11:00 PM
6cycbird86's Avatar
Car: 88 GTA
Engine: 5.0
Transmission: Manual
Axle/Gears: 3.45
YES !! please help-- last night on My way home my car suddenly loses 2nd gear and it also felt like neutral- the rpm shot straight up and i had to do 30 the whole way home- im a v6 auto not quite a GTA but please tell me its a sensor and not a blown tranny- yes this is a sort of odd coincedince
Old Aug 6, 2002 | 11:18 PM
86_Dan_Z28's Avatar
Car: 86 Z28
Re: PLEASE HELP Daily Driver GTA lost 3 & 4 gears
3-4 clutch pack is gone, time for a rebuild.
Old Aug 6, 2002 | 11:52 PM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
WELCOME TO THE BOARD!
MKerbouchard, I'd say you've got bad luck with trannys. First your Blazer and now your GTA. Maybe you should just drive
r e a l s l o w.
p.s. I need to borrow back my G-Tech. Making much better top-end power with 350 ESC module and knock sensor.
Old Aug 7, 2002 | 12:23 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
HAd the same thing happen on my 91 GTA. I just got the tranny back from the shop they had diagnosed the failure as the 3-4 clutch pack. 1700 dollars is what I paid for a tranny that was good for 650 horse.
Old Aug 7, 2002 | 12:38 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
my pro-built just showed up today
and yes i lost the 3-4 clutch pak in my original
Old Aug 7, 2002 | 07:53 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Mean 5.7 your not to far away from where I am at. Do you run your car at Joliet? If so I would be interested in heading up there sometime. It is easier to go to a track with someone who is already familiar with it.
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
