Transgo Recalibration Kit Install
Old Aug 7, 2002 | 01:24 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I just bought the Recalibration kit. I hope to get the Corvette Servo and boost valves soon.(Pro-built, I will be calling soon) I was just wondering how difficult it is to install all of this. I do a lot of work on my car(i.e. headers and exhaust), but I have never messed with transmissions. The kit consists of a lot of springs and **** poor instructions. Is there anyone out there that has installed this kit (other that the professionals)? I called around and only one place would even touch this install and their charge was ~$250. What do you guys think?
Old Aug 7, 2002 | 01:30 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The kit can be a PITA to install especially if you have never messed with a valve body before. If that $250 includes fluid I'd say go for it, if you cant afford it plan on a full days work and take your time. If you have messed with a valve body before it should only take about 3 hours or so.
Old Aug 11, 2002 | 02:30 PM
4L60bliss's Avatar
$250 seems a little pricey, but if you have no clue about transmissions, it may be a wise investment. TransGo tells there distributers NOT to sell to consumers, so I don't know how you got it. I'm not trying to be a jerk when I say that, but I have seen to many people damage their tranny, then blame the kit when something went wrong If you can get your hands on the video that I hear is out there somewhere, it would be a definate plus.
Old Aug 11, 2002 | 05:52 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Anybody out there got the video?
Old Aug 11, 2002 | 09:52 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I have the video in my kit. It's very entertaining but not extreamly detailed. I have not installed the kit yet either. But I got a pric of $140 from a shop around here. :rockon:
Old Aug 11, 2002 | 10:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Not ture, TransGo sells kits to anyone and thier grandmother Summit and Jegs have them redialy avalible with the video. I guess thats why Probuilt sell them cheaper because they do not include the video but trust me the video was not worth the extra $$$ I spent going through summit. My brother got the SK at half the price from ProBuilt minus the video.
Old Aug 12, 2002 | 12:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I recently installed a TransGo reprogramming kit. Prior to that my total experience with
automatics was changing the filter. Having worked on every other part of a vehicle
I figured that a little-ole-auto wouldn't be much trouble.
It was an experience, no doubt about it. A world of springs, valves, wires, and snail-trails.
In the end it all worked rather well. I didn't even have to drop the pan a second time.
Once the kit arrived I read & re-read the instructions. With the factory shop manual and
the instructions I went through all of the parts figuring out what was what.
The baggies & labels came next. The parts associated with each step was placed into
a baggie and labeled to the step number. This paid off as I had a baggie with a spring
in it left over. Hmm, forgot a step (change spring). As I worked on each step I checked
and double checked. Drill size, hole to drill, spring to use, ordering/direction of parts. Used
a magic marker (sharpie) on the separator plate & marked the holes to be drilled or filled.
Then double checked it against the instructions. And triple checked it once I was done.
If you can follow instructions and are good with hand tools, then you should be able to
do the install properly. It took ~8 hours to do the work. This included doing some
things twice. Such as after replacing the shift shaft seal, I needed to take the
mechanism apart again to get the rod engaged into the manual shift valve (after installing valve body).
RBob.
Old Aug 12, 2002 | 06:33 PM
4L60bliss's Avatar
SSC, maybe thats the difference, none of mine have the video, and I was told when I got "on board" w/ my wholesaler that I could re-sell whatever I wanted, but had to put a disclaimer on the TransGo kits. I'm sure al the "Jr" kits are sold everywhere, and I guess all the "reprogramming" kits for the general public come with a video.
toronto formula
Nov 10, 2015 06:17 AM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
crazynights
Aug 21, 2015 06:53 AM
drathaar907
Aug 6, 2015 04:20 PM
