help 2nd gear started slipping
Old Aug 7, 2002 | 11:19 PM
sslee's Avatar
I rebuilt my turbo 350 2 weeks ago and it has worked great until today. I came home from work and jumped in it and when it shifted into 2nd it went to neutral, but when I let off the gas some it goes back in. It shifts fine and 1 and 3 work great. I can drive it if I give it no more than 1/3 throttle and 2nd does fine. I checked the govenor and the 1-2 piston on the side of the tranny but is there a valve stuck or something?? Please help, I hope I don't have to pull it back out.
Old Aug 8, 2002 | 06:02 PM
transfixleo's Avatar
Not sounding too promissing. Did you use metal or Teflon rings on the 2nd Accumulator (on side)? How was the bore for the Accumulator? Was it scored from a previous broken spring (common)?
Old Aug 8, 2002 | 09:18 PM
sslee's Avatar
Damn I am stupid.. When I put the valve body back on, one of the pins that holds the 2-3 or 1-2 shift valves in (i can't remember which it is, its the center valve on the side of valve body), fell out and I didn't know it. I pulled the pan off and there was a pin laying there and the valve was sticking out 1/2 in out of the body.
Anyway it works great now after I fixed the valve.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
