Manual Torque Converter Switch
Old Aug 26, 2002 | 05:51 AM
StocRoc's Avatar
I have already done a search and I found many results, but my question still hasn't been answered. Is there a way to wire in a toggle switch to the converter so that in one position the car runs normal like from the factory, but in the other postion the converter is unlocked all the time? I read the tech article but it is the opposite of what I want to do, it locks up the converter all the time. If this is possible, what wire/wires do I need to splice the switch into. thanx
Old Aug 26, 2002 | 08:00 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
You will need an SPDT relay and a switch.. Different manufacturers of these relays make them differently. Look for one with a #87A terminal (in the center of the relay). I prefer Bosch. Some have two #87 terminals. This will not work. Wire it in the following manner:
Isolate the ECM to torque converter wire at the ECM. On a 1987 305/350 TPI, it is tan/black. Cut it at the ECM. One loose end connects to #30 on the relay. The remaining loose end connects to #87A.
Connect #86 to an ignition source.
Connect #85 to a toggle switch at either terminal.
Connect the remaining switch terminal to ground. Finished!!
Now with the switch ON, the relay is energized, opening the circuit on the factory tan/black wire. Although the ECM will command lockup, the converter cannot because the circuit is open.
Old Aug 26, 2002 | 12:08 PM
StocRoc's Avatar
Willie thanks for all your help. Do you happen to have the part number for the Bosch relay? I can't wait to hook this thing up. Thanks again
Old Aug 26, 2002 | 07:12 PM
Willie's Avatar
I used to buy the relay & socket (connector) for $9 each from Crutchfield. And I don't even use the socket... Then I found:
Parts Express
937.743.3000
http://www.partsexpress.com
(looks like part sex to me!!)
Bosch 12V, 30A relay
#330-070
$1.99 each!!
And if you want the socket:
Relay Socket
#330-075
$1.29 each
Willie
Old Aug 26, 2002 | 10:02 PM
StocRoc's Avatar
Thanks again Willie. You are the man!! :hail:
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
