T5 4-3 shift problems
Old Aug 27, 2002 | 12:52 AM
pjw67's Avatar
I have an 89 bird with T5. When i shift up through the gears the tranny works fine. Under hard or easy throttle...no problems. It doesnt even grind into reverse at startup. The problem I have is I cannot shift from 4th to third gear. The shifter just wont go into third gear when Im cruising in 4th...what I have to do is shift from 4th to 2nd with the clutch in then back into third. It doesnt grind, it just wont go in unless i go back to 2nd then to third. Bent fork? Syncros? Any help would be great.
Old Aug 27, 2002 | 06:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bent or broken keys in the 3-4 synchro, or worn 3rd blocker ring where it goes up against the keys
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
