Stay 9-bolt OR Go 10-bolt
Old Aug 28, 2002 | 06:27 PM
89project's Avatar
My first question is. Did GM make a 10-bolt Rear, WITH discs, that will fit my 89 IROC, our thirdgens, and if so how common are they, what did they come on?
. My 9-bolt needs new bearing, seals, posi-unit, and might as well add gears for fun. But the price to fix these Rear ends, makes this decision hard to swallow.
So I am debating whether or not to just get a hold of a 10-bolt and rebuilt that with all the goodies. I want to swap out my gears anyway, and I could actually put in a solid limited slip. Hell I could even throw in new axles for the price of a few 9-bolt bearings.
So what do you guys thing. My car is an 89 IROC 350, daily driver, AND THE WHINING AND SQUEAKING COMING FROM THAT REAREND IS GETTING REAL ANOYING. How's that for whining and squeaking.
Old Aug 28, 2002 | 07:00 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
i am sorda in the same boat. my 9 bolt posi does not work, the original 3.45 gears have been changed to 2.77 gears for some *** unknown reason!!! 3.73 gears for this thing are 295 bux, and i have a 2 series carrier thanks to the original owner. not to mention the price of a new posi unit!!! i am defitnitley in the market for a 10 bolt with disc brakes and a nice gear ratio. i was so excited about this rear end when i bought the car, ( i knew it had 2.77's, but i DIDNT KNOW the posi didnt work) and coem to find out it is nothing but a money pit. i could trash 2 10 bolts for the price of refubing this piece of junk. i wish i could just find another 9 bolt, but they are few and far between. sorry for ranting, i would go with a 10 bolt if i were you.
Old Aug 28, 2002 | 08:36 PM
89project's Avatar
Anybody happen to remember that article in CHP in July, how to intstall gears in a 10-bolt. They rebuilt a 10-bolt, axles, gears, and posi, some labor. for only 1000 bucks. From where I sit, looking at what i need in my 9-bolt. That 10-bolt is looking better.
Anybody else got any input. It would be greatly welcom.
Any experiences in swaps. Or anything at all.
Thanks.
Old Aug 28, 2002 | 09:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a 9 bolt for sale. Everything works and it has the 3.27 gear. I want $275 for it complete from caliper to caliper including rotors. It would be pick-up only but I am 30 minutes south of chicago. If interested e-mail me at eighty4z28@wideopenwest.com
If you want to take off the cover and look at the gears, etc. I have NO problem with that.
Old Aug 28, 2002 | 09:36 PM
bubbz89's Avatar
Car: 1990 RS
i wish i was closer to chicago!!!!!!!
Old Aug 29, 2002 | 10:01 PM
89project's Avatar
Does anyone have any ideas where I could research this info on my own.
Anyone know anyone that knows someone.
Anything would help.
I was also curious,
The brakes are interchangeable, RIGHT?
Old Aug 29, 2002 | 10:33 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I researched on building mine, to get the carrier replaced was like 600 bux. There is a link here (on thirdgen) that has shims to tighten up the limited slip diff. I helped my buddy with his 89 9 bolt, bearings, seals gears etc..we got it together forjust over $550. I've never seen a 9-bolt break, there was a low 11 sec car here that ran one. Although the posi was trashed (big supprise).
anyway I wouldn't waste the money to build a 10 bolt, they just plain suck, unless you invest a ton of money into them. Just my 2 cents...
Old Aug 29, 2002 | 11:09 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
That thousand bucks IS IF you do it yourself. I did it, but wouldn't do it again. If I had it to do over it'd have a 12 bolt under it. just my 02.
Old Aug 29, 2002 | 11:56 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
But do you two get change back if the question was "A penny for your thoughts?"
I believe Stephen 87 Iroc had a 9 bolt running high 10s with 3.27 gears on his dragster. Sounds mighty tough to me!
Old Aug 30, 2002 | 01:50 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Im running high 11's with a 9-bolt and 2.77 gearing... of course the posi doesnt work anymore... *sigh but I noted if I backup about 10 feet before I do a burnout both tires spin, it sort of locks the posi or somthing. i guess its "on its way" out. both tires still spin during the 1-2 shift chirp and around corners... and it hasnt realy BROKEN yet. thank gawd...
Old Aug 30, 2002 | 05:28 AM
bubbz89's Avatar
Car: 1990 RS
thanks for the info guys!!!:hail:
Old Aug 30, 2002 | 12:39 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've got brand new posi's available for 445 at www.9bolt.com
Miles
Diff Solutions
Old Aug 30, 2002 | 06:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was running high 11's/low 12's with 3.27 gears. Never had a problem.
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
bigjay89gta
Oct 15, 2015 08:04 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
