T-56 700R4 swap
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
T-56 700R4 swap
After swapping a T-56 into a third gen, has anyone then installed the 700R4 back into the 4th gen? Does it work?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
why wouldnt it work? as long as u kept the old stuff from the r4 u should be fine.
Car: 88 Firebird
Engine: 302 SBC
Well, the radiator needs to have a place to hook up the cooling lines. Will the radiators swap around? Will the third gen shifter work in a 4th gen console. Have to find a different console too. Will the electonics(speedo and computer) hook up and work yet? Steering column probably not set up to use the key to release the shifter from park. On and on I would imagine. Just wondering if it has been done by someone.
Hello, Michael
Aug 20, 2015 03:19 PM
