How can I go WOT in 4th with a 700R4?
Alright, this has been bugging me for a while, and I'd really like to fix it. What do I have to do to be able to go WOT in 4th? As it is now, it doesn't matter how fast I'm going (120MPH, or whatever) if I hit WOT, my car downshifts to 3rd.
What can I do to fix it?
Last night I got to run my first 1/4, and at the end I was close to 6500rpm in 3rd. I think if I could get into 4th at WOT I could shave off a few extra .1.
Any ideas?
Any ideas?
Car: 1990 IROC
Transmission: TH700-R4
you have to be running at less than 70% throttle for the trans to shift into OD. i know B&M makes a part that will allow the trans to shift into od at full throttle, i just cant find the PN right now.....
The GM part no. is 8673948. If you do install this part you may have to recalibrate the governor and the 3-4 shift timing spring because it will go into overdrive to early and bog down the motor.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Re: How can I go WOT in 4th with a 700R4?
Any ideas?
Any ideas?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You were at the top of third gear BEFORE you hit the big end with 3.73 gears & you only ran a 14.3 ? Something is wrong with this picture.
And it was my first time, so I don't know if I was shifting at quite the right points.
Something just doesn't add up, I agree. I go through the traps in third gear, somewhere between 4500 and 5000, doing 103 MPH and I have 3.73s. I wonder if you have some slippage (either in the transmission, or a real high stall converter)
xbazzarex
Dec 1, 2015 05:25 PM
