TH350 prob: Reverse wont work unless
Old Sep 7, 2002 | 12:49 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
when it gets hot my TH350 will not go into reverse unless I hit the throttle a little... then it bangs into reverse. by HOT i mean operating temp (160-170*) while COLD everything works fine. reverse is the only gear affected, ALTHOUGH 3rd somtimes when HOT (operating temp) 3rd will come in later than usuall..
Old Sep 7, 2002 | 07:18 AM
transfixleo's Avatar
Rebuild.
Old Sep 7, 2002 | 02:42 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Reverse is the first gear more times than not to go. The only other thing to check is the fluid level. Check it at the temp it is giving you problems. If there is enough fluid and it isn't burnt, then rebuild.
Old Sep 8, 2002 | 02:23 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
eh rebuild? doh. but all the other gears work fine! oh well. Ill wait till it blows then rebuild it ok?
camaro11j
Sep 19, 2018 08:49 AM
Fronzizzle
Aug 17, 2015 02:52 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
