hydraulic clutch problem
Old Sep 7, 2002 | 02:27 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
ok,this sucks. i was leavin my neighborhood last night n my clutch kinda popped,i felt it in the pedal atelast, and it wouldnt go into gear,its hydraulic. it had pressure but i couldnt get it into gear. then it started working again. now its working,but i wanna fix it before it does this when im somewhere important. i dunno if this ahs anything to do with it,but a while back id have the clutch pressed down for a lil bit n itd loose all pressure and start engaging the clutch,if anyone has any ideas,lemme know,thanx
Old Sep 7, 2002 | 08:09 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Sounds like you have a slave cyld going bad. Check for leaks, low fluid, or air bubles. Your fluid could be going bad or low. It could also be a sinkro problem just a thought.
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
