700r4 replacement alternatives
Old Sep 9, 2002 | 01:53 AM
phil's Avatar
Car: 1984 trans am
Engine: 305 ho v8 stock
ok here is my question i have found its cheaper to get a used or even a new 700r4 tranny to replace mine. but i have also found other trannys are even cheaper i would like to know which other trannys i can put into my 84 trans am without having to do too much alterations. my t/a has a 305 carb. with 700r4 tranny right now thanks....
Old Sep 9, 2002 | 06:58 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Not sure what your question is. You say other transmissions, are you referring to ones such as a THM-400 for example? Or are you referring to different rebuilds? The simple way is to stick with the 700. It's a decent transmission after a proper rebuild and you will not have to worry about linkage issues etc. Pro-built, or taransfixleo are here on the boards and can give you advice on what to look for in a rebuild.
ede's Avatar
ede
th350 with b&m pn 30299, i ithnk the same of a th200 a th400 will work with aftermarket torque arms. make sure you don't get one with a BOP bolt pattern.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
dutch930
Sep 11, 2015 06:58 AM
Thornburg
Aug 25, 2015 01:46 AM
Leggman1
Aug 6, 2015 04:15 AM
