Best Advise on rear end
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
The rear end is still stock in my car (2.73 gears)and i want to upgrade that next. I was thinking on going with 3.43 gears but with a 5 speed i might want to go with 3.73's not sure on that yet, but from what i understand i will have to change the carrier in the rear also so i might just want to go to a junk yard and pull the rear out of a Z-28 or IROC that's compatiable with my car. Anyone got any other options that they can give me? And i am on a budget here. Thanks !
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
from what i understand. you can also get 3.xx ratio gears for a 2 series carrier. that would work in your current rear. ocrrect me if i'm wrong.....
you can buy gears for your carrier, look in jegs catalog. it'll say something like y:yy ratio gears set for x:xx and numerically higher(or lower) carriers. what they do is make the ring gear thicker so it all works.
Car: '94 Corvette
I'm going through the same crap, & personaly I would buy a good quality 3 series carrier (after market), along with Richmond 3 series gears.
In fact, the more I learn about these POS 7.5/10 bolts, I'm saving money on my credit card to get a 12 bolt ($2000, BUT I won't be replacing a rearend any time soon
BTW: If your 5th is lower then 1.00 ratio, then I would go with a 3.73!
Ron
) !!!BTW: If your 5th is lower then 1.00 ratio, then I would go with a 3.73!
Ron
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Best Advise on rear end
Even with overdrive, I'm turning 2400 rpm at 70 mph on the highway with my 3.42s. 3.73s would be unbearable at highway speeds, IMO.
hey david i got richmond 3.42 gears for a 2 series carrier brand new that i could sell u , reason i wanna sell them is now im wanting to get 3 series gears so i can buy a new differential.
Give me an email if ure interested
camaroz4lif@yahoo.com
around 100 sounds good i paid $ 190ish for them
Guys I have 2 series 3 carriers and 2 series 2 carriers and the following gears, 2.73, 3.42, and I think the other is a 3.2x. If anyone is interested make me an offer. Thanks. Also I just acquired a 4.11 if interestd. Jeff P.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
