Transmission Lines Leaking!!
Old Sep 22, 2002 | 02:46 AM
Fade2blk500's Avatar
First off,
I own a 1985 z28 camaro. It has a 305 gm crate moter and 700r4 tranny. Its primered down with a 4 inch cowl hood. (tried to be as ******* as possible). Anyways, I just put a new transmission in it about a month ago. All of the sudden it has began to leak transmission fluid, not shift, and when it does shift, slip reeeaallllly bad. I pulled it up on ramps to take a look at it and to my suprise the transmission lines were leaking, where they connect to the transmission. I figured they might be loose so i grabbed a wrench and tigtened them up. Cranked it up, still leaked. What do you guys think the problem may be? Is there maybe a seal or something that goes in there? The lines are not stripped out and they are tightening up. Any reply will be greatly appreciated.
-Craig
Old Sep 22, 2002 | 10:29 AM
Nordbert's Avatar
Lines may not be seated squarely on fittings and the seat wore
from vibration. I would get a different fitting and line and splice it with a compression coupler. I hope you didn't lose clutches
as a result of the fluid leak.
Old Sep 22, 2002 | 08:10 PM
thanks for the info, i will take a look at it tommorow when i get off school. I hope this fixes it. Also, i dropped the transmission pan and didnt see any more metal shavings than from normal wear and tear, so i do believe the clutches are still in good shape.
-Craig
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
formula_novice
Aug 18, 2015 08:48 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
